- Jan 7, 2019
- 236
- Plaster
- Pentair Intellichlor IC-40
Heated pool for kids, as such temp is higher than normal. Typically has been around 52.
Using Taylor K-2006.
water temp 87, FC 5, CC .5, PH 7.8, TA 90, CA 280, CYA 70, CSI .16
Curious about testing FC. Kit says use two dippers of powder. I’ve tested using one dipper as adviced here and also have used two dippers. When doing both, I get two different reads for FC.
My CYA seems high. Pool builder started me off using tabs. Several months went by before switching to liquid chlorine. Should I drain to get lower level or just keep FC higher?
Thanks
Thanks
