New stain on pool liner
Canucklehead
68
SW British Columbia
Hello everyone.
A new problem, noticed only today after several days of leaving the solar cover off. 20 or more of these black, comet-shaped marks, ranging from an inch to 4-5 inches in size, in one corner of the poll's shallow end. They do not vacuum off, and they do not brush away!
Please, someone tell me what is happening, and what can I do about it. I hope the jpeg makes it clear what's going on.
Thank you!
Canucklehead
68
SW British Columbia
Uh, the jpeg doesn't seem to attach. Do I need to use a different file format? I tried a PNG, but it was too large for the server to handle.
mknauss
44,310
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
The forum's server host is having difficulties with attachments. Seems like some folks are able to get them through but it is not consistent. So might want to wait until tomorrow and try again.
mknauss
44,310
Laughlin, NV
Fiberglass
Did you fertilize the lawn in the last couple days?
Canucklehead
68
SW British Columbia
No fertilizer, but good thought. I did use lime on the lawn 2 days ago, so the timing fits. But it was deployed on the opposite side of the pool...
Could lime - CaO - do this?
mknauss
44,310
Laughlin, NV
Fiberglass
It would create very high pH in an isolated area and if you have any iron in the water, it would come out of solution.
Take some vitamin C tablets, put them in a thin sock, crush them a bit, and set on the stains. If they disappear, it is iron.
YippeeSkippy
17,612
Evans, Georgia
Any oak trees over the pool? We have had tannin stains before from tree debris. A little higher on the FC helps remove ours.
