Good day,
I have a brand new heater purchased online. I placed it on a pad and installed the 2" plumbing with check valve to it. All straight runs in and out. Hooked up the electrical per the manual instructions. Had the gas company run a new line to the heater. Gas company pressure tested the line (2 psi) and it passed. The gas line has a Maxitrol regulator in line 325-5L. 2 psi Po 7" - 11". All hooked up and ready to go. Gas company leaves after town inspector passes their work. They did turn the Honeywell gas valve to On for us. They made it clear that they just run and hook up the gas per code to the unit and they don't work on the unit itself. So they left and I tried starting it. Turned up the temp higher than the pool and spark spark spark 16 times doesn't ignite. I shut off the valve and walk away. Came back a bit later same thing. Tried it a bit later and after 14 or 15 sparks it fires. Said ok maybe needed to get rid of air in the line. It wasn't on more than 15 to 20 seconds and bang bang bang (kettling) coming from the unit. I turned it off. Went on Raypak's site to see who does warranty work. Called two of them and they said they only work on things they install. Told me to call Raypak. I couldn't find a tech support number only sales. So I emailed them they told me it was a flow problem. I have a Hayward variable speed pump 4 speeds and when I run the pump water going thru the heater at any speeds it comes out at the pool as it did before the heater was installed. There is no slow down or restrictions from the pool water just running thru the heater without calling for heat. I put it on speed one on the pump and turned up the Temp to call for heat and I got a SW error on the heater. Looked that up which is low flow. Said ok let me take it to the highest speed and ok the heater is happy and tries to spark the pilot. Spark spark nothing. Walk away came back a little later. Same thing. Came back and tried again and after several sparks it started (again on the highest speed) and then bang bang bang. Emailed Raypak they said it was a flow problem. They told me to check the governor which I did boiling water test all is fine. They said try it with the governor out which I did. Took a few attempts to get it started but again after several walk aways and retries it fired. Bang bang kettling again. They said see if the by pass is stuck. I took the header off and the bypass had about an eight of an inch where it didn't get seated down all the way at the factory I assume. Tried again still bang bang bang. While it was running I tried to reduce the shut off valve outside the unit that the gas company has on their line and when doing this I did get the noise to stop and it sounded fine and I was getting a 8 for the flame. Was getting heated water out of the side of the pool. Raypak keeps telling me it's a water flow problem. How can it be a water flow problem when the units pilot light won't ignite 99% of the time and I have to throttle the gas line feed down by 75% to get the banging to go away. The gas company is coming out today to see if he can get the pilot to work consistently but I suspect their is an issue with the gas valve and all I am getting is finger pointing. No warranty service unless Raypak referred warranty company installed the unit, Raypak canned response flow issue and gas company saying their stuff is fine. Very very frustrated. And I had the unit on the pad waiting for the gas company after setting up appointment and the return window ran out but then I find out that Leslie's won't let you return a heater anyway. Now I have $$$$$ sitting on a pad not working. Anyone go thru anything like this before and have any good suggestions?
