New Pump, 1 yr old filter, losing pressure after running pump for 1 hr
ronatola
21
Oshawa, Ont
I had the same issue with my old pump.
18 ft above grnd
old pump hayward 1 hp new pump 1.5 hayward hp
After I do a 10 second backwash the pressure is ok for the next hour
Jimrahbe
15,023
Bedford, TX
Ron,
You do not have a pump issue, or even a mechanical issue... You simply have a chemical issue.
You have algae whether you can see it or not.. It quickly fills up your filter until you backwash it..
I suggest that you perform a SLAM on your pool... SLAM Process
Jimrahbe
15,023
Bedford, TX
Ron,
Why would I lie to you??? :)
Please post the following numbers...
FC
CC
pH
TA
CH
CYA...
You may be the first, but so far I have yet to find anyone that has a problem where the filter clogs in a short period of time and then works again after a quick backwash where the problem was not algae...
Or maybe I just did not read your post correctly.. :scratch:
