New poolman dumped DE into the pool, not the skimmer.
ajw22
23,984
Northern NJ
Pentair Intellichlor IC-60
Add half of your normal amount of DE to your filter so the grids has some coating.
Run your pump 24/7 and your filter should capture the DE over time.
Watch your filter pressure and backwash when the filter gets loaded up with DE.
What pool cleaner do you have?
ajw22
23,984
Northern NJ
You will need to see how much DE settles to the floor and can be vacuumed.
TFP_Addict
117
Burbank, California
Just added 3 poundsish. I'm gonna let it run for 12 hours and vacuum tomorrow, the sun already disappeared. Worse comes to worst. I'll just remove the grids after 1 week and clean them off again and reapply the DE.
What else can yo do really. :cautious:
TFP_Addict
117
Burbank, California
This morning I found the spa half empty. This is the first this has ever happened since I replaced the spring flapper pool check valve 2-3 years ago.
Could this be related?? or is my check valve failing?
ajw22
23,984
Northern NJ
I can't imagine how the spa half empty is connected with dumping DE into the pool.
Could be a failing check valve.
mknauss
36,395
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
Hard to say why it failed. Low pH would be a detriment as they have a metal spring.
