I have been reading these forums for awhile now and have been trying to soak up as much information as possible, but I would love the advice of expereinced pool owners. I'm using a TF-100 test kit and just used it for the first time. The pool was finished in December and the pool company has been mainting it and just recently turned it over to me. Its been pretty cold and rainy for weeks now, so I'm not sure if and how that effects these results. The water looks ok, but it's been cloudy here. The Pool builder has the filter running from 7am-5pm everyday and the pool cleaner running 7am-11:30am everyday. They have the Chlorinator set to 20%, but its not running due to low temperature. Hopefully I provided enough information with my results. Just wanting to know if my numbers are ok or if there is something I should be concerned about or something I need to add. Thank you for your time!
PH-7.8
FC-2ppm
CC-3ppm
TA-80
CH-150ppm I did this test, but wasn't sure if I needed to? The color was never really red it was more of a pink?
CYA-65
Temp of water-41 F
Temp of Air-44 F
CSI- -0.58
PH-7.8
FC-2ppm
CC-3ppm
TA-80
CYA-65
Temp of water-41 F
Temp of Air-44 F
CSI- -0.58
