- Aug 22, 2018
- 46
- Plaster
- Pentair Intellichlor IC-60
Hello all. We filled out pool roughly 12 days ago and I’m making way into the startup process. My question is when do I start adding all these various chemicals. So far I’ve only done MA, CH, and liquid chlorine. Right now my readings are as follows,
Ph 8.2
TA 80ish
CH 170
Chlorine doesn’t register even though I added some.
Please advise on when I should start with adding CYA and also should I dial in the chlorine also? BTW I’m using the TF 100 kit with speedstir. I’m getting the hang of it.
Ph 8.2
TA 80ish
CH 170
