- Sep 19, 2020
- 5
- Plaster
- Pentair Intellichlor IC-20
Hey all, still getting quotes on new pool and have some questions.
This is my first experience with a pool so trying to get an understanding of everything.
I'm in Hilton Head, SC and pool is going to be a small (4800 gal) inground design. Equipment quoted so far:
Pentair Intelliflo variable speed pump
Pentair Hi-rate sand filter with Hi-flow multi port valve
Automatic chlorinator
1 - 400 watt LED pool light
AquaCal Heat/Cool heat pump (SQ166R)
Also, I am being given a choice between the Pentair Salt/Chlorine generator or a Heyward HydraPure water sanitizer UV/ozone oxidizer combination. Cost is the same but some builders are pushing one and others going the opposite. Looks like on here a lot of you prefer the Salt.
Any suggestions or input is very much appreciated.
Thanks
Thanks
