Hello TFP!
Just bought a home recently with a 23,000 gallon fresh water, in-ground plaster pool. I knew nothing about pools and inherited this one with the purchase. To add to it, the previous owners let it go a few days before we took possession and then we were out of town for 2 weeks. Needless to say we came home to a swamp. We ended up needing to replace the main pump due to corrosion (got the previous homeowners to cover this) but treating the pool myself (I REALLY didn't want to drain it, and every one around me was booked up for a month) has been a 2 week saga. I discovered TFP via reddit.com/r/pools and this place has been a lifesaver. The following is a brief timeline:
- Came home to swamp, took advise of pool repair guy who replaced pump and bought a case of Leslie's Powder Plus 73. Opened 2 bags into a bucket of water and dumped into pool. I don't think the pellets fully dissolved (this will be important later)
- After a few days of no progress and pool turning dark green, I read TFP, pool school and learn about SLAM. I order the Taylor K-2006c.
- First test shows PH too high, I buy Muriatic acid and add WAY too much since I failed at directions. I buy sodium bicarb to balance it back. I start SLAM with 10% liquid chlorine.
- No results after 2 days, I test CYA and it's off the charts. I buy a small pump and drain half the pool and refill. CYA is now 40.
- 8/9 days of constant SLAM at 14FC. After 5/6 days in I realize my filters are breaking and music be super old, I buy new cartridges. I start vacuuming and brushing/skimming daily. Between the brushing (this was key honestly) and the new cartridges, SLAM having great affect.
- Upped my FC to almost 24 since I suspected I had yellow algae, and a few days later my water is crystal clear. Haven't passed OCLT yet but i'm only losing about 3ppm overnight so i'm close!
I think i'm on the right track and about to be stable but i'm considering removing my lights to clean behind them. I just today took the Polaris cleaner and (unused) tab floater out as I didn't realize they could be harboring algae. My reason for posting is mostly to understand my system as now that I can FINALLY see through the water I can actually see what's in my pool.
Thanks so much!
- Some questions based on pictures I included: My pool has tons of drains, like 5? Then with the skimmer and a suction port, is it normal to have that many? I know I can isolate the suction valves to figure out which one is the skimmer vs drains, I just thought it was weird there's so many drains.
- In the "Pool Piping 2" picture, my flow goes from the filter, then there's a valve for solar heating or gas heater, after the gas heater it goes to the returns, BUT there's this bypassed line with a valve, I don't understand what this is for. (the top pipe with the solid red line tracking it)
- Next to my suction port in the pool is another port that I have no idea what it's for. There's two of them in the pool. (see the "Suction port and something else" picture)
- I have 1 return jet in my pool with no flow. All other jets work great. This one jet (see "Return jet no flow" picture) will emit small bubbles for 1 minute right when I turn on my pump. I suspect since I have the Varispeed Pentair pump, since it primes on a really high RPM setting, it pushes something through this line but then when the RPMs drop, nothing comes out. How can I test/fix blockage on one specific return when all others work fine? Here's a videos of the bubbles when I first turn on the filter, after that, nothing.
- I have a few lights in the pool, not sure the brand. Some of the lights are installed on a curved section and therefore they're not flush against the wall. That's okay right? I imagine water gets behind them and there's probably algae growth there.
Thanks so much!
