New Pool Owner Needs Some Guidance!
pauly3dotcom
7
McAllen, TX
Hello Fellow TFP Members! New pool owner here down in South Texas and I am in need of some your knowledge and support. Pool was finished on Tuesday and finished filling up this morning... kids can't wait to jump in and honestly neither can the adults! Pool is a 15x30 (~15,000 Gallons) with offset infiniti edge spa 8x8 plus baja. We went with Quartzscapes Tahoe Blue in Pool and Spa and the baja is a Stonescapes White Mini Pebble! We are in love with the pool and color choices!
Pool Builder added 1 gallon of muriatic acid, the DE Powder and turned on the IntelliFlo VSF this morning! I added 16oz of 3-in-1 Surface Solution (Sequesterant) and the Pump has been running all day. I brushed the entire pool surface at 1:00PM and 10:00PM this evening. Builder added another gallon of muriatic acid this afternoon.
I did some reading in the Pool School section while the build took place and I ordered the TF-Pro with SmartStir Plus XL Kit! I have purchased the following items to help care for my pool although I know I need some additional items to get and keep the water right.
Already Purchased:
HDX 128 oz. Chlorinating Liquid - 10% (6 Bottles)
PoolTime Chlorine Stabilizer 5 lbs. Balancer (1 Bag)
Muriatic Acid - (4 Bottles)
Here are what I believe to be the water readings, sorry first time using kit and I am learning:
FC - 0.00
pH - <6.8 (Solution was Yellow)
TA - 0
CH - 325
CYA - 0
Where do I go from here? What else do I need to buy? Borax, Backing Soda, Calcium Chloride?
Cwiggs
212
Phoenix, AZ
CircuPool RJ-60 Plus
Looks like you are off to a good start. Have you read the plaster startup guide?
The main thing you should do is get CYA and FC up. You can use the sock method to get the CYA in and while it's dissolving poor the bleach in to get your FC to the right level.
FC/CYA Chart
After that you should report back so we can help you fix the TA/pH issue.
clambert1273
991
Gilbert, AZ
CircuPool Edge-40
FC/CYA Chart
72 hours before adding cya, after adding cya by socks & dissolved (takes me about 15 min after letting them soak for 30min) then dosed my chlorine it's been pretty stable
clambert1273
991
Gilbert, AZ
CircuPool Edge-40
Yup mine was a 10lb bag of powder, if I have to add more than a lb then I uss multiple knee hi's all around the returns
pauly3dotcom
7
McAllen, TX
Thank You I understand now. I don’t have any direct returns in the pool as I only have 15 BlueSquare 360 pop up heads in the floor. Do I put instead in front of a spa jet or do you recommend I put somewhere else?
mknauss
39,005
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
You can place the sock with CYA in the skimmer. Be sure it does not block off water flow. Keep pump running until the CYA is completely dissolved.
clambert1273
991
Gilbert, AZ
CircuPool Edge-40
If its in a sock can put in skimmer basket & let soak for 30 min then start squeezing or just let soak then get in pool walking around squeezing (I do that since im in it anyway)
Shirker
682
Athens, GA - USA
This is my preferred method. But I have a vinyl liner. If you do this, might just have to make sure it does not wander to the side of the pool and rest against your plaster.
ACtC-3dTxZFEHDXEK7EdMSlW3hv61yKX-Io9I0QrSYBRsE4hpYfzW3aFVI9hhM6s1yetMthA0si7FY9kCXLullSLlEi7v5zfD-T2cdmFwaZ77fLSdGLGSo5Y7q6Gd_OBTrUWQleXnxXgKVCOWIrlaKS_R53LAg=w1920-h909-no
wireform
In The Industry
Aug 15, 2017
2,283
Spring Valley, NY
If you use the skimmer for dispersing the CYA, DO NOT backwash for the next week as it'll take time for all of it to be in the water.
