New pool owner, first test with TFP kit
azswimmer1
3
Phoenix
New home/pool owner in Phoenix, just did my first test and here are the results. What would you suggest going forward? Can we make it throughout the season without draining- it’s starting to get hot here. 16k, previous owner had puck floater. Pool is clear, no apparent problems.
Water temp 78
Chlorine 5
Ph 8
TC 2.5
CH 625
CYA >100 (leslies/test strips around 150)
TA 110
Texas Splash
Well, with a CYA of 100 or more it will be difficult to manage the free chlorine that goes along with it. To help you ID the true CYA, you should go the CYA test page HERE and do a diluted test starting at step #8.
When CYA or CH becomes too high, most in your area do a water exchange (if needed) before it gets much hotter to the exposed plaster. You may not have to empty your pool, but I suspect a large water exchange will be needed to lower the CYA. Easy math, a 50% water change should lower the CYA in half. It might also help with your CH.
Reactions: azswimmer1
mknauss
36,977
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
As Pat said, easier to exchange some water now.
Your CH is not very high so this pool was drained not too long ago.
I would suggest doing an extended CYA test to confirm what level you are at.
If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
  1. Fill the mixing bottle to the lower mark with pool water.
  2. Continue filling the mixing bottle to the upper mark with tap water.
  3. Shake briefly to mix.
  4. Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
  5. Continue the test normally from step 2, but multiply the final result by two.
azswimmer1
3
Phoenix
Retested CYA with dilute and no dilute. This time with back to bright sun. We are getting more like 90 now.
mknauss
36,977
Laughlin, NV
Fiberglass
Great. You should still plan to drain off some water. But up to you. See FC/CYA Chart
pH testing is not valid when your FC is above 10 ppm.
