New Pool Looks real Blotchy
carnivalday
585
Ocala, FL
Just having a pool put in recently myself, Im thinking I wouldnt have been very happy had mine turned out that mottled either. Hope you can get a resolution for this.
schuetteknight
46
Melbourne, Florida
We just had ours finished with a similar condition. The pool builder called it the "fat" from the plaster. Make sure they are keeping chemistry correct. Our pool used a TON of acid for the first couple of weeks. Ours is at about 4 weeks post plaster and it is looking slightly better. Lots of brushing and maintaining a Ph of around 7.2. good luck!!!!
jhbrfla
16
Boca Raton, FL
Thanks! My pool builder tried adding a lot of acid and it helped a bit but not much. Will be draining the pool and acid washing and hope that it looks good after that. I'm lucky Florida Stucco came out and told the pool builder that it is not an acceptable finish.
Reactions: carnivalday
engrav
Platinum Supporter
519
Whidbey Island, WA
Hi
I took one of your pics and circled an area. That is what the National Plasterers Council (when I had this problem) called normal cloud-like appearance of dark plaster dye, as the cream cannot be distributed evenly.
Also included the document from my contract.
We decided to skip the acid wash as builder said improvement might be only 50% and would shorten the life of the plaster somewhat. But was tough call and I suspect there is no "right" answer.
I do wish we had received a sample prior demonstrating the cloud-like appearance instead of the one we received which was uniform.
  • White and Colored Pool Finish Agreement.pdf
jhbrfla
16
Boca Raton, FL
Hi
Have to say that in person it looks much worse than the photos. It only looks "ok" if its windy and the water has a lot of ripples on the surface. Kind of have no choice but to try the acid wash. I will read a bunch and watch videos about how to acid wash and will be taking the day off from work when they do it and will do my best to make sure they at least do that right. Fortunately I haven't made the final payment to the pool builder and won't unless it comes out acceptable.
jhbrfla
16
Boca Raton, FL
So here's the update. Pool builder drained the pool and acid washed. It doesn't look perfect but it looks much better and I'm definitely happy with how it looks. Thanks to all for the input! Here are some pics.IMG_3294.jpegIMG_3301.jpegIMG_3302.jpeg
Reactions: PoolGate
ajw22
25,663
Northern NJ
Pentair Intellichlor IC-60
If you are happy then we are happy.
Go swim and enjoy your great view.
Reactions: jhbrfla
markayash
3,072
Atlanta Ga
They had to do the same to mine, what is strange is it seems to be a common issue. Are PB not doing something correct so the "top" layer wears off?
My plaster guy argued with me for 4 months telling me " your chemicals aren't correct" then told me to dump 6 more gallons of acid ( PH was already at 7 ) and see what happens..Thats when I pushed back..
Reactions: jhbrfla
ajw22
25,663
Northern NJ
@onBalance has written extensively about the plaster practices required for a quality plaster job. Links to them are at Plaster Installation and Maintenance - Further Reading
ajw22
25,663
Northern NJ
Good article, wish Plaster guys would read that!
I wish pool owners would come here before they do their plaster instead of their first post often being asking about a plaster problem.
Reactions: markayash
