New Pool Heater Mastertemp 400 not working. no regulator on gas line.
Deblur1
16
Austin, Texas
Mastertemp 400 is getting gas but wont fire. Pentair told me it was because of no regulator. Is this true? if so what regulator do I need? When trying to firing igniter stutters. They told me i need 6-8 lbs of gas pressure.
JamesW
17,359
We're going to need lots more details.
Is this a new installation?
Who installed the heater?
Do you have pictures of the heater?
Natural gas or propane?
RedBluePool
In The Industry
Feb 24, 2016
96
Spring/TX
If you go to fire your heater up and then when gas valve opens up and then you hear fast repetition of clickng then you will need a regulator on your gas line. That gas pressure might break your gas valve.
JamesW
17,359
You should leave the heater off until you can get a qualified professional to check the heater and make sure that everything is correct.
douglasj76
Active member
Aug 27, 2017
43
Westlake, Ohio
How long is the gas line to the heater, what size is it, and what is the service pressure your entire house runs at? Also do your other gas appliances have regulators on them?
