New pool (first time) build in DFW (Current Phase: POOL COMPLETED!!)
Steel went in yesterday
Does that 'demo wall' have filter, heater, etc in the loop? The head loss due to the piping is a fraction of that through a filter and heater.
Good point ... I don't remember what they had there besides the pipes as it has been quite a while since I was in the dream center or whatever they call it. Very nice showroom.
Joe, @joel98z
I had assumed that it was part of the main pool pump and filter plumbing, but it is not..
I now assume it is a pre-filter for water going to one or more of your water features. If that is true it makes more sense to have it.
Please tell me what the pump right below the pre-filter is going to run.
And, if you can, show a pic from the side showing pre-filter and associated plumbing.
I like the way your builder has individual valves going to most pipes.. As an example; your Skimmers and Main drain all have individual 2-way valves.. This is much better than trying to use 3-way valves for skimmer and main drain control..
@Jimrahbe I verified with PB that the pre-filter is for the pump running the water features. Below is pic from side showing the pre-filter and associated plumbing
Two weeks from dig to Gunite!
I am curious to know, if anyone sees a problem with where the salt cell is placed?
That should work fine. I personally would have liked it to be on that horizontal pipe from the wall to the front as it may be easier to service but it appears you have access to that backside.
I really like how the plumber used Jandy 2 way valves on each suction and return for better control and those valves are serviceable if needed in the future.
Reactions: joel98z
Thanks @HermanTX , The reason I ask is that someone on another forum mentioned there should be a check valve before the salt cell to prevent damage to the heater from treated water. Also they said the chlorinator should be before the salt cell because salt cell produces chlorine gas that could react with chlorinator causing an explosion. But we will only be using the chlorinator for the first 30 days while plaster cures so they will not be used together.
First, the SWCG only produces chlorine when pump is flowing so no need for check valve. With an inline chlorinator, the chlorine can flow back thus the need for the check valve. Once you start the SWCG, you can disconnect the hose from the side of the inline chlorinator and put 1/2 NPT plug in both holes. Alternatively, you can turn the controller to zero to stop all flow if you do not want to remove the black hose. The inline chlorinator has a check valve internally on the cylinder so no flow will go into the cylinder from the pipe to which it is mounted. Also, remove all pucks from the inline chlorinator.
Reactions: joel98z
Tile went in late last week. I not sure it was a good idea to choose bright white grout. Is this going to be a nightmare to keep clean?
I love that tile! We were really close to choosing the same tile.
I think white grout looks great! But I can’t comment on maintance.
Thanks!, Its what my wife wanted.. I think its a little busy but its growing on me. Some additional pics:
electrical went in today!
@joel98z Do you know why you have 2 antennas? I have the iAquaLink 3.0 which is the one on the left that gives you control via PC or phone app. What is the Black one on the right control?
Now just waiting plaster and water fill. Good Luck.
I have no idea what that other antenna is for ?? I will ask PB
