New Pool Build Leander, TX(Austin) - Decking
joshlarsen
Active member
Apr 27, 2021
36
Leander, TX
Pentair Intellichlor IC-60
I spoke to my super and took a pic of the manual that states their should be a check valve between the heater and chlorinator/SWG and said he sent that info to the plumbers. Sounds like they have been doing it wrong for everyone.
All I know is Im going to make them do mine right.
Reactions: Turbo1Ton
jetski559
Active member
Aug 20, 2020
33
Central Coast California
For me, it seems a lot of the PB's and tradesman are cocky and don't want to be told what to do by their clients. After all, they are supposed to be the professionals?
Why does it take some clients that are picky to sit there and have to catch mistakes the 'pros' are making?
Really makes you wonder all the other things you didn't catch... Stresses me out. And how sad for all those other people who it was done wrong for...
Turbo1Ton
663
NE Oklahoma
Pentair Intellichlor IC-40
I had to point out to my PB that the heater manual said there needed to be a 36" clearance between the heater and outdoor AC units. They had mine shoved right next to it and I told them that we needed to move it and they told me they had been doing it like that for years. I told them I would compromise and we could do 24", because we really didn't have a lot of room.
It drives me crazy that people don't read instructions.
--Jeff
Reactions: BigPapaSmurf
joshlarsen
Active member
Apr 27, 2021
36
Leander, TX
Well gunite day has arrived. The crew showed up this morning shortly before 7 and had all the prep done and had started shooting gunite about 7:35.
My super had the plumbers come out on Wed and they swapped the DE filter with a 520 cartridge filter and added a second pump for the bubblers instead of using a valve off the 1 pump. They put the new DOE compliant single speed 1.1SFHP Pentair Whisperflo(015583) pump in for the bubblers. They also added a 5th return and looped the returns in the pool like I had asked. Only plumbing change that I want them to make yet is to add the bypass around the heater and add a one way valve between the heater and the puck feeder/SWG.
I'm still debating about having them just remove the puck feeder when they do the plumbing rework.
joshlarsen
Active member
Apr 27, 2021
36
Leander, TX
The mason guys came over the weekend and put the coping on. I have never really been really happy with the original tile we had chose but we chose it because when we went to the supplier we told them we were interested in either a 1x2 or 1x1 tile and they only showed us about 10 different tile samples and we chose the best one. Last week I got to thinking that was ridiculous to only have that small of selection so I contacted by designer and said that doesnt seem right which I should have done 1.5 months ago when we were choosing selections but anyways he said they have way more than that and said they must have only showed you the level 1 tile. I sent a text to the supplier to make sure it wasnt to late to change tile and sent a pic of what I was thinking and she said we can get it but its backordered till end of Nov and was a level upgrade. I told them to switch it and the upgrade was only $575 so well worth it in my opinion. That makes our original estimated completion of end of Oct get pushed to sometime in Dec as long a the tile comes in in Nov. Superintendent said he would continue with decking, firepit, outdoor kitchen, electrical, and finish off the plumbing in the meantime. I would rather delay some now and have something I really like than something I always wish was different.
Decking guys had started on Monday but stopped to get some plumbers to remove the pipes from the pad to the pool because they didn't burry them low enough for the decking to go over the top of them. Plumbers are here today so I'm guessing the decking guys will start again later today or tomorrow.
So here's progress pics
Selections - This has the original tile
New tile
TexasEd
Active member
Sep 11, 2020
41
Austin, TX
Jandy Truclear / Ei
your coping and tile look like mine. You should love it.
Reactions: joshlarsen
joshlarsen
Active member
Apr 27, 2021
36
Leander, TX
Well short update. We had a couple days of weather delay and a short delay to have the plumbers come back and remove the pipe and dig their pipe trench deeper to the equipment pad and relay the pipe and pressure test again because the trench wasn't deep enough for the decking to go over the top. I knew it was going to be an issue all the way back to when it was dug because I could see the depth wasn't deep enough but I cant call them out on every detail and some of the stuff they are going to have to find the hard way. I cant imagine not having any knowledge of plumbing, electrical, and mechanical and just trusting the PB to do everything right.
Decking prep is close to complete just need drains and concrete and then kool deck. On sat it sounded like they were hoping to pour cement this week but they haven't been around so far this week. Were waiting on tile till end of Nov anyways so they have some time to get it all completed.
