New Plaster Startup
ShallowWater
52
Riverside, Ca
Here's my Tap Water Chemistry assuming the salt and CyA is 0 (not tested).
Fill water going in now. Tomorrow I'll need to start balancing.
Results from poollogger.com
FC: 2.5
CC: 0
PH: 8.2
TA: 100
CH: 150
CYA: 0
Temp: 65
Salt: 0
CSI: 0.41
kimkats
48,137
Tallahassee, FL
AHere is a set of links I put together to help with plaster picking and start up. The second set is how to care for the pool after it is started up and balanced.
Plaster links:
Ten Guidelines for Quality Pool Plaster Best one of all
All Plaster Finishes Should Last 20 Years
Not All Color Pigments are Good for Pools How to pick a good color for plaster.
A Plastering 'Watch List' | Professional Watershaping | Watershapes
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
What did you use to test the water?
ShallowWater
52
Riverside, Ca
Plaster links:
Trouble Free Pool
Trouble Free Pool
Pool care links:
Print these out:
Bookmark these:
Trouble Free Pool
I buy my reagents in bulk from Amazon suppliers to refill my TF 100.
ShallowWater
52
Riverside, Ca
Based on my numbers I need to boost CH by around 32 to 35 pounds. Is it best to float a sock like with CyA or should I merely broadcast it around the surface of the pool?
ShallowWater
52
Riverside, Ca
BTW, @kimkats I already had the plaster done when I posted. The existing plaster lasted about 17 years so not too bad. The W/C in the mix "looked" to be a pretty high slump so that may be an issue as with the use of a curing agent as I'm not sure. The water itself does have trace metals in it but sans having a softener I suppose I'm stuck with it as is. It did take a crew of 8 about 7 hours to do my pool and they didn't do too much "hard tooling". At any rate, the pool looks great right now and we're selling the house. Next time, when I build my own pool, I know a few more things to be mindful of so thanks for the links.
