New Pentair pump replacement
Genec
5
Seaford, NY 11783, USA
Made the mistake and left my pump out over the winter. Seals and bearings are shot. I was looking to replace my 011773 (WF26) 1.5hp with a newer model.
I have a 30-35k gal pool. I am confused as to whether my pump truly runs at 1 or 1.5hp. Nobody seems to have a 1hp (011059) or 2hp (011060) but there are some 3hp around.
I have seen the 011018 and 011056. Is there a significant difference between those two? And can I use the 3hp but at lower power or is that a waste?
PS dont want to have to repipe.
ajw22
41,372
Northern NJ
Pentair Intellichlor IC-60
Welcome to TFP.
011018, 011028 and 011056 pumps are all basically the same. Get whichever one is available.
Running the pump at a lower RPM/HP will save you lots in your electric bill.
Read How to select the best pump for a new pool
ajw22
41,372
Northern NJ
GPMs depend what your equipment needs.
There is no optimal run speed. It varies based on your pool environment, time of day, weather, season, etc.
What problem are you trying to solve?
Genec
5
Actually not having a problem just trying to replace my 1.5 hp Whisperflo. I never invested in the Intelliflo because as I said more to break.
However they seem to be phasing out the single speeds. I have a 30-35k free form pool and that 1.5 worked fine for me until I left it outside for the winter...
ajw22
41,372
Northern NJ
