FC: 1.8
CC: 1.8
pH: 7.7
TA: 120
CH: 100-125
CYA: ?
Water temp: 79 deg
Hello all, I had 2 pools growing up and helped with assembling them, testing, vacuuming, backwashing, winterizing, etc. so of course I thought I knew it all! ? However, my family has had our first pool for 3 days and I'm already getting confused.
The first thing is the chlorine. We have some sensitivities to it in our family (we think) and so I started out aiming for the minimum level of 2 ppm FC. That in mind, I added a quart (32 oz.) of 10% bleach from Walmart the past two nights in a row. When I tested the water yesterday morning, the FC and CC were both 0.6. So I added another quart of bleach and we had a couple relatives over to "test drive" the new pool. Last night about 11pm I added more bleach (maybe 1.25 qts) and this morning at 10am the FC was again only 0.7 with CC showing a bit higher, maybe 0.8. So it seems this pool is a chlorine eating monster right now.
Stabilizer -- I haven't added any but obviously need it. I don't know how much to add because my current test kit doesn't test CYA... our local stores don't carry the "good" kits so I have to order one ASAP but in the meantime I don't want to screw up the water.
Acid demand -- the test indicated 1 cup is needed. I have some dry acid from Leslie's.
Yesterday, pH was 7.8, today it is 7.7. TA has shot up, from 100 yesterday to 120 today. I should also mention that both nights, we ran the filter all night (about 10 hrs). The pool has so far remained uncovered.
The kids are complaining that the water stings their eyes and noses, and according to them it happens immediately, the very first time they go under the water. This probably isn't a sunscreen/goggles issue because they swim in other pools with both those factors and no problems.
OK, so after all that --- What to do next? I've added the last of my chlorine today (a little less than a quart) which brought my FC and CC to 1.8, so I'll be making a trip to Walmart. Should I also add some acid and/or stabilizer? How much? And more importantly (according to the kids anyway) when is the next time they can go in?
CC: 1.8
pH: 7.7
TA: 120
CH: 100-125
CYA: ?
Water temp: 79 deg
