New owner, first tests
thelyonsking
11
Ohio
New owner of an old pool that came with house. Intex 12 x 24 8400 gallons. Sand filter. So far I have been able to scrub and vacuum all the Crud out.
Since all I had were some old strips left by previous owner I took a sample to the store yesterday.
TA 47
pH 7.2
CC 0.6
They had me add 12 lbs Bio guard Balance Pak, 2/3 cup Lol n Slo., and I added a chloride puck to the two floaters.
This morning strip says
FC 5
TCI 5
ALK 180
pH 6.8
TH 250
I just ordered a TF-100 test kit to do better testing. The water LOOKS decent. Hopefully I can make sure it gets balanced out with better testing.
That is most important. :goodjob: Everything else above doesn't really help much I'm afraid. I wouldn't add anything else to the water except some liquid chlorine each day - about 3 ppm worth. You can use our PoolMath APP (Effects if Adding) to help you with the dosage. Once you get the TF-100, post back with your numbers and we'll have some confident advice ready.
Enjoy! :swim:
Reactions: Stump
