- Mar 5, 2021
- 55
- Plaster
- Pentair Intellichlor IC-40
Thank you @kimkats @Jimrahbe and @JamesW ! So, a pool consultant I spoke with suggested a Superflo vsp for water features. The height of the wall is 30” for middle wall and 18” for wall on each side. Would superflo not be sufficient? Just asking as it is a bit more economical I think?. And currently have a 420 filter. Also not enough?I would go with a 4" suction line and then run a separate 2" line with a Jandy Neverlube valve on each line to each sheer so that you can get perfect balance.
I would run the water through a 520 square foot cartridge filter.
