@Rich D Dirt is not something i have a shortage of. After back fill they will move some of that around back to form a more gradual grade.
They will be scraping the sod layer anywhere decking will be and then i will cover it with the fabric.
re: collar drain, at this point the only thing i can do really is fill the pool trench above the collar with sand and then put the 3/4" gravel on top of everything.
Im not sure if that is a better solution than just backfilling with all gravel.
Id have to do the drain myself and truthfully I don't really know exactly how its supposed to be done.
I would think having the decking span 10ft in each direction over the pool excavation and sloping away from the pool it should mitigate the majority of any water pooling that could happen in the backfilled trench.
