New IG Liner Seams question
westbrook215
Active member
May 9, 2016
40
Princeton,NJ
Had Merlin liner installed this week. Shallow end floor to wall Sean is about 2-3” from the wall and appears to not be sucked into the corner, like a ramp effect. It has been 48 hours since install.
after liner was installed 11000 gallons was trucked in.
I have them coming back out for unrelated tasks but what is acceptable regarding the bottom floor corners?
kimkats
45,747
Tallahassee, FL
Have you been in the pool to feel it? It might have stretched some and it is okay. So long as the liner is touching the wall, cove, and bottom it is all good. If there is a large area it is not touching I would be worried about someone stepping on it and causing to over stretched and rip.
kimkats
45,747
Tallahassee, FL
Newdude
3,651
NY
To the best of my knowledge, mine doesn’t either. She may have had a brain slip and thought it was an above ground, But then again, Kim being Kim......... I’d bet that she is right and both of our pools are wrong.
