- Feb 8, 2019
- 8
- Plaster
- Jandy Aquapure 700
I'm a new pool owner and I just recently added a heat pump to my setup. I have a Jandy iAqualink system and when the system is installed the water temperature sensor was placed on one of the pipes. The pipe where it was placed happens to be on the supply line to the heat pump.
The problem I am experiencing is that the heat pump will turn on and run for about 5 minutes and then shuts off, about 30 minutes later this happens again.
I think I have a problem with the temperature sensor being on the supply line, is this the proper location for this sensor?
Thanks.
Thanks.
