New Guy Questions (Pentair's IC40 Set-Up)
Boogfj40
10
INDY
We just had our Thursday's (14'x35') Aspen (9,000 gallons) fiberglass in-gound pool installed this past October (2019). I am already thinking about converting over to SWG. I am currently looking at Pentair's IC40 model.
The questions I have are as follows:
1. Would Pentair's IC40 be to large for my 9,000 gallon pool?
2. Do I need to purchase a separate flow cut off valve switch or does this model have one installed inernally?
3. What is so special about the transformer to run this unit that makes is cost $400? I currently have a 300 watt Intermatic transformer running 2 LED pool lights, Could I run the IC40 off this transformer?
4. Do I need to worry about my aluminum coping corroding from the salt?
5. How do I know how much salt to add during initial start-up?
Thanks for everyone's advice!
tim5055
10,464
Franklin, NC
I'll answer teh first one and let our SWG experts chime in on the rest-
We always recommend a SWG that is sized two to three times larger than the pool volume. So, this unit is perfect.
Reactions: Boogfj40
Jimrahbe
15,698
Bedford, TX
40,
I am a big Pentair kind of guy, but unless you have a Pentair automation system, then the IC40 is not really your best choice..
The IC40 runs off of DC voltage, not AC voltage, so your landscape transformer will not work.
It is always better to have too larger a cell vs. too small of a cell.
The IC40 has an internal flow switch.
The amount of salt is shown in the manual of any SWCG you buy..
I would recommend that you look at one of the CircuPool models as a lot of our members have reported good success using them.
They are always having a sale where you pay for one model and get the next model up for a buck.. I would use an RJ model and not any of the SJ models.. I recommend you look at the RJ20 or 30.. But they have others as well.
Boogfj40
10
INDY
Thanks for the info. The reason I asked about the transformer is because it's output is DC and only running to small DC LED lights. I don't see why it wouldn't be possible to run the SWG off of this since it is a 300 watt output.
How does the ICHOR30 compare to the IC40.
Thanks Again
Boogfj40
10
INDY
40,
Just looked into the CircuPool models. You're right, The reveiws are really good. Maybe I should go this route..... Thanks
