- Apr 16, 2020
- 36
- Plaster
- CircuPool Edge-40
So I started reading on here about a month ago after purchasing my first home (completely new to this). With strip tests and bleach and some trial and error the pool was sparkly and clear in about a week's time. Unfortunately lockdown came about and I ran out of bleach. It quickly became a green, moldy mess. I had to use some tabs to keep some chlorine in there being careful not to overdo it and get my CYA too high.
Anyway today my big order of 10% bleach arrived, as well as my Taylor k-2006c test kit. I have some liquid muriatic acid and about 10lbs of baking soda left over.
Here's what I got
Apx. 10,000-12,000 sqft in-ground gunite pool.
Hayward cartridge filter (I clean it all the time), as well as baskets.
2 built in jets opposite of skimmer
Drain is capped off (I would assume there's a leak)
1hp pump, running 8hrs a day.
Skimmer is on the wall but in a canister in the pool.
As soon as the bleach came in, I added 2 gallons just on a whim (very slowly into deep end jet) and started scrubbing the floor which immediately released green mold, ran pump for about 2hrs before testing and voila my test kit arrived.
FC 22 (first time came in at 17 next time 22, same sample water)
CC 1.0
PH 8.5 (I guessed since it was over 8)
TA 10
CH 300
CYA 60
Since the test, I added about 8-10oz of of 31.45% muriatic acid in the deep end jet very slowly (I was recommended 7oz with the app).
Waited 20 mins added about 9lbs of baking soda (app said like 10lb but I have 1lb left just in case I need to adjust).
App says to add 3oz more of 10% bleach (what I use) for SLAM @ 24ppm, about to do that.
Any other recommendations? The house came with a cheapy suction pool cleaner which I run from time to time.
Here's what I got
CC 1.0
TA 10
CH 300
CYA 60
