Bought a house with an in ground plaster pool. Plaster was falling off the walls. Algae was growing like crazy. After reading this site I bought a CYA test kit and I basically could never see the black dot so it was well up into the high 100’s. Prior owner said he basically threw shock in it once a week and had a chlorine tablet foster.
We knew we had to re-surface it and re-tile it when we bought the house to I nursed it along and turned a green pool nice and clear for a couple months. We decided to resurface with pebble sheen. It also needed a second drain added to be up to code. It has a 6’x6’ spa about 2’ above the pool that has a spill way into the pool. Pool is 34’x14’ approx. My rough calculations is about 16,000 gallons. Its a play pool about 5.5’ deep in the middle and 3 on the sides. Water was filled a week ago and I’m adding acid daily with the cheap test kit the builder gave me. PH seems to go up a little each day.
They put a lot of CYA in it to keep chlorine from burning off. I tested it today and it’s around 90-100. I think he added too much but what’s done is done. I’ve put about a gallon of chlorine in it this past week. The pool is in the sun all day with no shade.
I just ordered a Taylor 2006 kit to stay on top of the chlorine since the test I have won’t go past 5. I’m learning as I go but it’s kinda.
