We just signed PB contract and moved into our new Frisco, TX home here in 2017. Our new home has a builder installed soaker/drip line around entire post tension cable slab and is integrated into irrigation system. Our pool will be dug with water's edge only 5ft from home slab, due to limited back yard space. The decking choice we made will be concrete pavers. Overhead image attached to show decking and pool orientation to house
FYI-pool builder will have soil injections underneath excavation to limit soil expansion and I believe the land developer followed the practice of installing plastic sheeting approx 6-8ft below grade as the method to control moisture levels (sorry I don't official term for this method, but is what I watched them do to the new construction phase behind us, so I can only assume they did the same for ours....)
My question is related to slab irrigation/drip line and the challenges to maintain the slab's integrity since we are digging pretty close to it, and potentially removing the drip line . Should I expect that drip irrigation should be left all around home perimeter and installed under the pavers or what is the best practice to ensure the best chance for slab's performance here in N Central TX clay soil? What the are the pros/cons of making sure it remains under the pavers to maintain moisture levels on that side of the slab? Thanks in advance for any feedback
