Hi! I've been doing tons of reading and appreciate all the posts and thread responses. Being new, I am not sure quite where to start.
We picked up a used Summer Escapes pool last year, and with it came the standard pool pump (330 g/hr with a small paper filter). I calculated it should be about 3500 gallons max being 14' round with a depth of 32". I had hoped to transition to a larger pool this year with a sand filter, but everything was sold out by the time I made that decision.
So at this point, I am trying to get this pool up and running and solid for this season, with a plan to upgrade next year on package that includes everything (so I am trying not to invest in something that I may not use after this summer). I did order a pump that can filter 1000 gph and hope to have it tomorrow. Now that you have some backstory, I'll start with my questions...
I took a sample into our local pool store and they suggested I add 2#s of granulated chlorine (which I dissolved in a bucket and put into the pool) and I added 1/4 pound of stabilizer 3 days ago.
I am using the clorox test strips, as I was told I didn't need to use the drop kit and all I can is that all of my test readings are low: low hardness, very low total chlorine and low free chlorine. pH is 6.2 and total alkalinity is very low.
It has been very hot here in Boise, and my kids are in the pool everyday. I added an additional 3 # of Clorox shock to the pool last night assuming we would need to stay out of the pool for a few days and to get the chlorine levels raised. The pool is very cloudy and still no free chlorine is showing.
At this point, what do I need to do? Does pH and alkalinity need to be correct prior to get chlorine right? Or does chlorine affect the pH and I should target correcting chlorine first? Should I wait for the new pump to arrive and run it continuously to get out the particulates in the pool? Drain and refill and start over? As you can see, I am spinning in frustrated circles right now...tough bc I had an in-ground pool growing up and we had little problem keeping things right. And now that my kids have no camps and are out of school, the pool may be our lifesaver this summer (if I can get it right)
And I assume I need to keep everyone out of the pool right now??
Thank you!!
Thank you!!
