New Build So. Cal -running updates! start up finally 😃😃
S S
109
Los Angeles
Im long over due on an update . .. things were stalled for quite a bit, due to fires, winds, rain, more fires and permit delays . . . :( a few months behind schedule...
8/15 three mini bobcats have been working for three days--soo much progress--
8/18 dig completed! (well I guess not)
8/20 went out to measure per Kim--NOT DEEP ENOUGH-called PB-digger used old plans . . . so need to come out another day TBD
8/21 steel --cancelled!
8/24 diggers came back/proper depth--allowed us to now also make spa bigger-we are 8*8 now
8/26 plumber visited for new spa specs--dug around some more
8/27 re-bar started
8/28 re-bar completed
9/16- shotcrete!!!
9/22 --we had a pond/stream--we were going to just change liner, but decided on a total overhaul!!
11/18 coping went in
11/25 pavers started
12/3 pavers complete! no more dirt!!! woo hoo!!
12/4 remaining retaining wall poured for equipment
12/7 title was supposed to start (tile guy is sick) . .
12/8 water line tiles in
dec/jan more delays- but completed the spa tile, wing walls etc.
2/6/2021 plaster
2/7/2021 acid wash and water
2/9/2021 start up!!!
2/12 fire/water bowls
floating steps remain - likely 2/12
pics at the end of the thread.
30*18 rectangle (depth 4' to 6'), with additional 6'3"*15 Baja shelf (water depth- at 9")
8*8 spa-10 jets (raised 24" with 3 spill over edges-two floating steps up)
18" retaining wall on north side with 5*8’ center wall with 1-5' sheer (pentair whisper flow)
Stonescapes (reverse tahoe)-added hand cast abalone/and glass
Stone black Tandur coping
pavers
2 firebowls, with water feature- separate pump
Equipment:
Pentair IC 40
Pentair 420 clean and clear filter
Pentair Intelliflow 3 H.P. 8 speed pump
Pentair Master temp 199K Heater
Pentair Rebel cleaner
3 globerites in pool 1 in spa and 2 microbrites in baja
Pentair 8 function EZ touch w/screen
4 returns and 2 skimmers (ty for the input on adding extra skimmer)
mknauss
36,075
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
I do not see any issues with the equipment. Be sure the Easytouch is not the LITE version.
Be ware of abalone shells added to the plaster. There have been reports of staining after time due to the shells.
Reactions: S S
S S
109
Los Angeles
Thank you for the advice--I will check on Easytouch--what is the other option you recommend? and what is the problem with the LITE version?
mknauss
36,075
Laughlin, NV
Fiberglass
The LITE version only allows 4 schedules. Be that a combination of Feature schedules or Egg timers. The regular allows 12. The LITE version does not come with the power panel in it, so you have to have an additional box on your wall.
The ET should have the SWCG power center in it. Be sure you are getting a SWCG that is rated for at least twice your pool volume. I suspect that will be an IC40
Reactions: S S
S S
109
Los Angeles
Yes— getting an IC40- updated my post above and added the layout Photo! Thank you for your advice
kimkats
48,005
Tallahassee, FL
LOVE design!
The one thing I would change is to go for a 4' shallow. That will ease the transition for the deeper end. I would also think about doing the steps all the way across the wall to the shelf. That would give you added seating inside the pool.
Reactions: S S
S S
109
Los Angeles
LOVE design!
agree with the 4' shallow end--Ill talk to PB about that--I am having trouble envisioning the second--are you saying extend steps and have them end where the shelf stops? or all the way across the length of the entire pool? I
kimkats
48,005
Tallahassee, FL
I put my idea in purple. My reasoning is this will allow you to have another seating area and the steps will be right by the wall so it can be used to help people get out of the pool if they need it.
I worry the way the steps were with that pointed corner there could be some hurt legs or body parts if someone was playing around in the pool and ran or swam into it.
Reactions: S S
S S
109
Los Angeles
That makes a lot of sense--maybe extend all the steps to the baja? I also called PB and changed shallow to 4' --I really appreciate your input and help.
kimkats
48,005
Tallahassee, FL
You could extend them all the way to the shelf. I only went as far as I did to keep as much of the shallow end for Watermelon ball. Look it up! You will love it!! Best pool toy/game out there!
Kim:kim:
Reactions: S S
Watershow
200
Riverside County, CA
Did you get your permits already? Just signed a contract last week and wondering what the turnaround time would be in Southern California. PB said it may take up to 5 weeks with the pandemci
S S
109
Los Angeles
Nope-it was under review and now the status is CORRECTIONS REQ --I assume that means they need additional information or something corrected. We submitted on 10th and paid/finalized on 18th. I was told up to 2 months :( --and then 1-2 weeks start from time of approval.
Where in So Cal are you?
S S
109
Los Angeles
Im actually glad things were slowed down in a way-we ended up making several changes since we had time to think and research a bit. I still have a few tweaks to make.
Watershow
200
2 months 😳. I’m in Riverside county. Guess by the time they start working won’t be until fall. I was debating whether or not I would need a heater for a pool only build guess I made the right decision? Lol. I’m in the same boat - so many decisions to make from coping to finish. Who’s your builder?
S S
109
Los Angeles
Kim:kim:
Kim —what do you think of this?
S S
109
Los Angeles
Pool Water Creations. Yours? Yes--definitely going to be fall . .. we added a heater
