Hey All,
First off, I would like to extend my gratitude to the collective community here for the support you have already inadvertently provided me as well as the future support I know I will receive. My wife and I are close to breaking ground on the first pool either of us will have ever owned. I found TFP a few weeks back by doing what I always do any time I'm about to do anything...researching that topic to death. Let me just say, this site has been a godsend as we have zero pool experience. The more we learn the more we realize we need to learn, but the tools we've picked up here in just a few short weeks have given us the confidence to know pool ownership isn't as scary a thing as we may have thought.
So, now to the reason I'm posting. After interviewing 6 or so builders and kicking the tires on the various pool types we signed a contract for our gunite pool on 6/12. We submit for permits tomorrow 7/20 (engineering took 5 weeks!), and then it's go time! Below are the details as they are today. There will be a pre-construction meeting with the builder in the coming days, and there are a few things from an equipment perspective, thanks to the knowledge I've gained here at TFP, that I will be looking to change at that time.
Specs
That's where we're at currently. Hopefully permits move fast, and we're digging soon. Any delay and we may be forced to make a decision whether we plaster this year or wait until the Spring.
Some pictures of our backyard below. Excuse the mess, it's a major work in progress.
I can't wait to share this experience with all your seasoned pros. All comments, recommendations, critiques of our current path are greatly appreciated.
Specs
- 18.5' x 44' (first 6' of shallow end is tanning ledge)
- 3' - 8' depth (1' on ledge)
- 31K gallons
- 2 skimmers
- 3 returns
- Some funky plumbing/valve scheme the builder calls solar recirculation; from what I can tell you can use your main drain as a return to circulate water from bottom to top
- Sunstone Select Cobalt quartz
- Belgard coping TBD
- brushed concrete deck
- Jandy Pro Series 1.5 hp full rated pump (will likely upgrade to vs or 2-speed)
- Jandy TruClear SWG
- Jandy 60 sq. ft. DE filter
- SQ145 Aquacal heat pump
- (2) full size Hayward Colorlogic LED lights
- (1) 320 Colorlogic LED light for tanning ledge (not sure how 1 light will be sufficient for a 18.5' x 6' ledge; considering adding a 2nd light?)
- Polaris TR-35P with 3/4 hp booster pump (will most likely ask to remove for a credit which I will put toward a robot)
- TF-100
- K-1766
- Speed stir
