Jbrillo
Can you elaborate on what to do with the hoses?oh yeah! And I see you knew what to do to the hoses! Well done! I am sure you know but...........don't let the flow of water stop. Doing so could cause a ring in that new plaster.
Remember there might be a slight green tint to the water. This normal. The final water color will come about as the water is balanced and the plaster cures.
Kim![]()
I need to start making a spreadsheet of reminders....SO much to remember!When filling for the first time you want to put socks on the ends of the hoses. This does two things-helps filter the water and keep the metal ends off the plaster. You also want the hose ends as close to the main drain aka the lowest part of the pool. This will help keep the water flow from causing a channel in the new plaster.
Kim![]()
Kim,When filling for the first time you want to put socks on the ends of the hoses. This does two things-helps filter the water and keep the metal ends off the plaster. You also want the hose ends as close to the main drain aka the lowest part of the pool. This will help keep the water flow from causing a channel in the new plaster.
Kim![]()
I'm very happy with the bronze spouts. The tile & coping crew did a great job.
Pool color looks great, too!!
I've been following your build because I think we'll be choosing similar color selections. Did you add any shimmering sea or glass beads to the blue surf?It looks much better now since most of the plaster dust is gone. Very happy with my color selections.
No, just plain Blue Surf. It looks great.I've been following your build because I think we'll be choosing similar color selections. Did you add any shimmering sea or glass beads to the blue surf?
Textured split face on the walls, smooth split face (with a slightly contrasting color) on the columns.So so pretty!!! Love it all! For your raised wall and columns- did you do split travertine?
