Hi there.
Never had a pool before, and spoke to a couple of pool companies in regard to an inground pool.
Have a few questions, as different companies seem to recommend different types of pools.
Want to point out that we had water table depth tested, and were told there is water at 5 foot 6 inches depth in the backyard. the first 5 foot 6 inches are all sand, after that is clay and bog.
We are planning to only have the pool go down to 5 feet at the deepest part.
First question is what is the difference, and what is considered better of having a pool made of steel wall with concrete vs a pool built with all concrete, built with forms, and made of 10 inches of concrete with rebar? Either pool will have a vinyl liner.
Second - pool floor - being recommended sand bottom, and also being recommended vermiculite bottom- what are thoughts on each?
Third- Warranty- What is typical warranty provided by new pool builders? Seems like proposals are not offering warranties except for manufacturers warranty on the equipment. One stated that if you use the pool, that we agree that it is fully completed satisfactorily.
Fourth- timing of the pool. -We have not picked a builder yet, but have started the permit process. Due to demand, builders seem unwilling to put a start date in writing on any contract. Verbally they are saying late July - Early August estimated start date. They have estimated if we go with all concrete, that the construction of the pool will take 4 weeks, and then an additional 2 weeks for the masonry around the pool.
If I use an August 1 start date as an example, that would get me to a completion date (including masonry), of middle of September.
At that point, being in NY, we would really not get much use of the pool in summer 2020. Is it worth it to even start construction at that point, or just wait until say April 2021.
Any feedback, here, or via message would be appreciated.
Steve
Steve
