Project Costs:
I will be very open with bids and costs. I am working with BYOP (build your own pool) so I have cost breakdowns from each vendor, including equipment.
Pool Equipment:
Description Qty Unit Total
Pentair; IntelliFlo(R); IntelliFlo(R) VSF; Variable Speed & Flow Pool & Spa Pump; 208-230VAC; 50/60Hz; 3200 Watts Max.; 1 Phase 2 1121.81 2243.62
GFCI Circuit Breaker, 20A, 115v/230v, Double Pole #PA220GF 2 138.39 276.77
Super-Pro; 21063-200-000 Above Ground Pool Pump Union Fitting; Hi-Temp; 2" MIP x 2" Slip (200-906) 6 16.2 97.21
Pentair Clean & Clear(R) Plus CCP420 Cartridge Filter; 420 sq-ft; 150 gpm 1 918.31 918.31
Pentair MasterTemp(R) Digital High Performance Low NOx Pool and Spa Heater; 400000 BTU; Natural Gas 1 2397.76 2397.76
Pentair Boost-Rite(R) TEFC Pressure-Side Cleaner Booster Pump; 1.1 HP; 115/230 V; 10.2/5.1 A 1 337.42 337.42
Pentair Racer(R) Pressure-Side Inground Pool Cleaner 1 834.7 834.7
Pentair ScreenLogic 2(R) Wireless Connection Kit Bundle For IntelliTouch(R) and EasyTouch(R) Automation Systems 1 479.5 479.5
Pentair IntelliBrite(R) 5g Underwater LED Pool Light; 12 V; 26 W; 100 ft Cord 2 669.06 1338.11
Pentair IntelliBrite(R) 5g Underwater LED Spa Light; 12 V; 18 W; 100 ft Cord 1 591.43 591.43
Hayward SP0600U DuraNiche(TM) PVC Large Lighting Niche; 3/4 - 1 Inch Socket; 45 Deg; Top or Rear Mount 2 79.42 158.84
Pentair PVC Small Niche For Concrete Installation/SpaBrite(R) and AquaLight(R) Light 1 68.51 68.51
Pentair Transformer; 12 -14 V; 300 W 3 137.73 413.18
Pentair Transformer; 12 -14 V; 100 W 1 128.6 128.6
Paramount 004-422-2026-00 Series 2 Ultra UV Water Sanitizer; 230 V-50/60 Hz 1 704.47 704.47
Pentair Water Pool And Spa Inc; T40FB; Autofill With Fluidmaster Valve 1 115.24 115.24
Super-Pro Hydrotherapy Jet Body with 4" Nozzle for Spas 6 20.41 122.48
CMP 25575-509-000 Water Stop Adapter Fitting; 1-1/2 Inch FIP x 1-1/2 Inch Socket; Clear 12 12.91 154.98
Super-Pro; 25552-401-000 Hydrostream Fitting; 1-1/2" MPT; 1" Opening; Gray 11 11.49 126.41
Pentair 580037 Niche Kit for ColorVision LED Light Bubbler 3 102.31 306.93
Pentair GloBrite(R) Underwater LED Light; 12 V; 100 ft Cord 3 321.1 963.29
Pentair MagicStream(R) 580001T LED Laminar; 16 W Maximum Per MagicStream Laminar; 120/12 VAC; 100 ft Cord; Tan Lid 3 849.92 2549.76
CMP Spa Air Controls Gunite/ Fiberglass 2 20.07 40.14
Pentair Water Pool And Spa Inc; 2" - 2.50" 3-Port CPVC Diverter Valve 5 64.57 322.85
Pentair Water Pool And Spa Inc; 2" - 2.50" 2-Port CPVC Diverter Valve 10 63.39 633.89
Super-Pro; SP0801-20H2 Check Valves; Slip x Slip; CPVC; 1/2 Lb. Corrosion Resistant Spring; 2" Slip; Heat Tolerant 1 41.64 41.64
Pentair WhisperFlo(R) WFE-6 1-Speed Energy Efficient Full Rated High Performance Pump; 1.5 HP; 208 - 230 V; 9.6 - 8.8 A 1 669.42 669.42
Pentair CVA24 Valve Actuator For 3-Port Valve; 180 deg 2 167.73 335.46
Pentair Sta-Rite SwimQuip ABS U-3 Top Performing Inground Skimmer with Lid and Frame; 2 Inch x 1-1/2 Inch NPT Reducer 2 110.05 220.1
AquaStar Pool Products 10AVR103 Round Anti Entrapment Suction Outlet Cover; 10 Inch; UV-Resistant Engineered Polymer; Light Gray 8 38 304
Trade Series Jandy 6" Extended Lip Sheer Arc Waterfall 1202CSA - Clear Lip 3 268.52 805.56
Pentair EasyTouch(R) 8SC-IC40 Control System with IntelliChlor Transformer and Cell For ScreenLogic 2 Apple(R) iPad(R)/iPhone(R) 1 2156.71 2156.71
Pentair IntelliChlor(R) Sanitizer Pass-Through Cell For Winter or Start-Up Easytouch(R) PS4/PSL4 Control Systems 1 52.74 52.74
Pentair 520670 IntelliChlor(R) Acid Washing Kit For Easytouch(R) Control Systems 1 29.82 29.82
