New at testing... thoughts?
bhoppe
3
Waco, TX
Hi everyone. Long time follower but just now got my TFTestKit and tested for the first time.
A few weeks ago the pool was green. 2 weeks ago it was super cloudy. Today it's mostly clear with a little bit of haze. Lots of small leaves falling.
Here are the results of my first test. I may have done some of it wrong but I have not been doing it the TFP way... yet.
Thoughts on what I should do at this point?
Current stats (I can't believe the FC would be that high. I have used some bleach and some tabs but that seems out of whack. It's definitely higher than 5 though!):
woodyp
11,042
East Texas
I would stop where you are if you're 2 weeks into this...holding 63 FC and still having cloudiness issues. I think your CYA could be MUCH higher than 100. I'd do a partial drain and check cya again.
Reactions: setsailsoon
bhoppe
3
Waco, TX
Thanks for the reply. I think the CYA is much higher because I was unable to see the black dot much below the 100 line on the CYA tube. As of today I would say the cloudiness is gone. I will retest but I think I'm going to end up having to drain some and refill.
Newdude
4,795
NY
You can’t guesstimate over 100. Halfway to 100 is not 200 and so on. You need to do a 50/50 dilution with tap water and double the result for an accurate #. Or 1 part pool and 2 parts tap water and triple the result. And so on. People have had CYA in the hundreds before and no amount of chlorine will hold a SLAM if it’s that high. Excuse me, 55 gallon drums at a time will, But yeah. Lol.
