New and Want to Make Sure I'm on the Right Path
Esloser
513
Millville, NJ
#1
Relatively new to pools and TFP in general. Was wondering if someone could take a look at my numbers and see if there's anything I should be paying attention to that I am missing.
PH = 8.0+ seems like I am constantly dumping Muriatic acid in. Probably using 2-3 gallons a week. Not sure if that is normal.
Trying to get the FC up. Using SWG.
jblizzle
41,197
#2
It is a little odd that your TA is climbing ... have you been adding fill water?
With a SWG running and the TA at that level, the pH is going to be constantly driven up. If you got the TA down to 50-60ppm or so, the pH rise might slow down.
You also do not want to lower your pH down to 7.4, see the low CSI? Your pH might be happier up around 7.8
OP
OP
Esloser
Esloser
513
Millville, NJ
#3
Thanks, May 1st was the day after opening the pool this year. The company that opened the pool vacuumed to waste the entire thing, so I did have to add fill water of about 6-8" to get it back up to the skimmer mark. Is the CSI in a good place?
jblizzle
41,197
#4
Your CSI has been all over the map ... should be kept between -0.6 and +0.6
And for a SWG pool, you want to stay a little in the negative to lower the scale production in the cell
