- Mar 16, 2017
- 47
- Fiberglass
- Hayward Aqua Rite (T-3)
Hello!
After much back and forth, I finally pulled the trigger and bought an 18x9ft Bestway Swim Vista pool from Costco. What I'm really concerned about right now is the installation. I had my landscaper come by to give me a quote. He is doing another AG prep in my neighborhood, and they are using decomposed granite as the foundation. Is this typical? I initially thought it might be too sharp for the bottom of the pool. But maybe with the liner, it will be ok. The manufacturer does not recommend sand. I would REALLY like to leave my sod in place and just put the granite over it to save money. Am I being too much of a cheapskate? My yard is pretty uneven. I understand we need to dig down to the lowest spot and not fill in to meet the high spots. After my granite/sand is in place, we need to water it and tamp it a few times, is that right?
After that, I need to get pressure treated lumber to go under the supports, correct? I read a few threads where people used pavers and they cracked.
And I know that I need to order a testing kit. I would like to switch to a better pump and a saltwater system pretty quickly. Should I just start out with the pump it comes with, get the hang of it, and then switch? Also, I'm totally in the weeds as far as setting up a SWG. I will check out some YouTubes. The forums are scaring me with tales of parts not fitting, etc. lol!
Thank you for all of your advice.
