Hi!
While I am new to this forum, I am not new to pool ownership and have successfully combatted algae blooms in the past with SLAMming the pool. This go round, I am baffled.
Before raising the chlorine levels, I checked my numbers:
pH 8+
FC 0
CYA 25
TA 40
I added muriatic acid to lower the pH and got it a little too low at around 7. I added 13 lbs of Baking Soda to raise my TA to 40(which I know is still low). I added 6 gallons of 10% liquid chlorine, Brushed the pool in its entirety. Several hours later, I tested the chlorine levels and got a reading of 30+. The next morning, there was no drop in the chlorine level, which was shocking. I continued to add chlorine thinking it was just a misread on my part.
Now, my pH indicates purple, which I know can be caused by high levels of chlorine. I read in another thread that lower water temps can make this process slower. Do I just need to wait and not keep adding chlorine? Please help!!!
Thanks in advance,
Piggulet
pH 8+
FC 0
CYA 25
TA 40
Thanks in advance,
Piggulet
