I haven't owned a spa in 20 years. Just purchased a home that has a 2008 Hot Spring Vista Spa sunken in the deck and would like your opinions.
1. When we viewed the home the water was warm. Water is now cold. Cant get the temp to display on the panel. I think the previous owner had the heater relay board replaced not to long ago. The panel doesn't appear to be locked. Any ideas?
2. I think the previous owner just kept tablets in and never checked the chemicals. I plan to use Ahh-Some on it and then drain/fill. I just checked the chemicals with my Taylor K2006.
FC 32.5
CC 0
PH no idea, bright yellow
TA was red after R0008 (should be green), quit here.
CH was clear after R0011L (should be red), quit here.
CYA out of reagent, ordered more.
The smell of chlorine will knock you down when you remove the cover. Water is clear but feels slimy almost like its pure chlorine. Like I said, going to use Ahh-Some and drain/fill it. Can I maintain it just like my pool. Anything I should do different?
3. We are not sure if we like the spa so low in the deck and we are thinking of putting it on top of the deck. Is your spa sunken or on top? Do you like it or hate it? The spa I had 20 years ago was on top and I liked it. It seemed easier to get into and easier to maintain.
4. The cover is original and needs to be replaced. Any recommendations?
Tim
FC 32.5
CC 0
Tim
