Hi Everyone,
I just replaced the motor on my pump with a 1HP 2 Speed BN37V1 motor. I have the correct switch/end cover assembly and wired everything up this weekend. With lots of excitement looking forward to the benefits of 2 speeds, I turned it on to "Lo" on the switch but its definitely in "Hi" mode, subsequently when I switch it to "Hi" on the switch it runs in what I believe is "Lo" mode for a few seconds and then stops spinning. All of my excitement turns to frustration as I started to troubleshoot.
I am thinking it must be the wiring, so I double checked everything per the diagrams on the pump and switch as well as reviewed this post: How to wire up 115v 2 speed 1 hp A.O. Smith motor
After checking all of that, removing and reinstalling all of the connections, double checking again, I believe I have everything correct but it must be wrong because nothing has changed in how the motor is operating.
I am hoping the pump/electrical gurus here can help me get this thing going correctly. I have some pics attached of the wiring so you can see what I have done.
Thanks in advance for your help and guidance with this.
