The sensor on this thing is not so good, I think. Or it's not well-calibrated to the adjustment range. Or I can't test while it's running? Zeropoint of 15 resulted in it turning on at 1.2 as I previously mentioned. Running for three hours then raised the free chlorine by 2 to 3.2ppm plus the dichlor I added, so that run time seems pretty good if I can get it to turn on at 2ppm or above. As you folks suggested, I increased the zeropoint, I think to 20, maybe 25 but I went too high I guess, because the next time I checked, the free chlorine was at 13 ppm with the cell still operating. Keep in mind, the zeropoint range of adjustment is 0-60. Anyway, I set it back down to 17, and waited for the chlorine levels to fall. We used it last night. FC before we soaked: 6.0ppm.
FC this morning, after we soaked, 1.4ppm and the cell was still off. So 17 is still too low. Bumped zeropoint to 18. Will wait and see.
