I opened my pool on April 26. It looks better than last year but I am starting to get nervous about next steps. I brought my TA down from 180 to 115 using dry acid. As a result my pH went from 7.8 to 6.8. I put my jets pointing up so I am making bubbles on the surface with the hope the pH will increase naturally. I don’t know if this enough aeration. I have my pump running full blast for 12 hours a day. At night I reduce it to two because it is on the outside wall of my bedroom and is noisy. I added one bottle of liquid conditioner on April 29. My CYA is still at 5. I think I need to add another one. My pool is clean but cloudy. Here are my numbers: FC .42, TC 3.62, pH 6.8, TA 115, Calcium Hardness 412, CYA 5, iron .1, copper .5, phosphates 3937, TDS 5000. I know the TDS and phosphates are really out of whack. What do I do first? Add CYA, do a SLAM or worry about copper or pH? Thank you.
