Greetings all and thanks in advance. We purchased our home in the winter two years ago and weren’t able to get a good pool inspection. The previous owner said it was perfect but, of course, there’s issues. This is our first pool and we’ve got quite a bit to learn.
The pool is a 30k gallon, cement, in-ground pool with two skimmers and a main drain. We figured out right away that the line from the skimmer closest to the filter was leaking. We isolated it and ran the one skimmer and main but we were getting air in the lines that progressively got worse. We let the pool go at the end of the season and now, I have the pool drained and am cleaning it.
We noticed a few cracks in some of the valves and we’re in the process of replacing them. Is it better to use individual two way valves per line or a three way valve where they join? I read an Amazon review that said the design of the three ways limit water flow. Also, is there a way to pressure test the lines without the pool being filled? The pool places near me say it can’t be done but (again, I’m a noob) shouldn’t you be able to isolate the individual lines and test them?
Another issue is with the main drain. I used it to lower the pool but it wouldn’t work for the last 2-3 feet. I’m thinking I may have clogged it with leaves/debris? I hooked up a shopvac at the filter and I could push air out of it (a lot) but it won’t pull water down. Can it be blown out with the pool drained? How about snaked?
Last few things: We’re on a budget, trying not to spend too much on materials and we’re doing the work ourselves. The walls look beat up but there aren’t any cracks. We’d like to just paint with rubberized Insul-x but how do you know if you need to replaster first? Also, I know glass tile at the waterline is easy to clean but can you use any tile that you’d use in a bathroom?
Thanks for all your help!
