You will need to increase your cya to around 70 to prevent the sun from eating the chlorine faster than your swg makes it.
use the sock method & add about 1/2 of what poolmath calls for then retest in a day or so & add the remaining amount needed to get to 70. You don’t wanna over shoot it.
As soon as u have the sock in the water assume that’s your new cya level & chlorinate accordingly-
FC/CYA Chart
Put the cell in & turn it on - is it the same ic60 as in your signature?
If so running it @ 100% for 10hrs a day should yeild u around 3ppm fc a day. Most residential pools use 2-4 ppm/day give or take.
You can play around with run times & percentages in
PoolMath effects of adding in the hamburger menu (select swg, then w/ the
select ic60)
Manage your ph with muriatic acid keeping it in the 7’s - this will lower your ta over time.
Turn on csi tracking in poolmath
Maintaining csi within
Recommended Levels will prevent build up on your new cell.
Only clean the cell if u see build up & even then try to get it off gently w/ a popsicle stick or credit card before resorting to cleaning it with diluted acid/vinegar as those dissolve the precious metals/coating on the cell & that decreases its life.
