Feel free to move this to the plumbing/pump section if that is the better place for it.
I have a 16 x 4 round Intex ultra frame pool that I upgraded to the 16 inch Intex sand filter pump this spring. I am currently using the small Hayward through the wall skimmer and the original Intex inlet eyeball, and I am Wondering if this set up is likely restricting the overall flow capability of this pump. I’ve been running it 4 hours a day and that doesn’t seem to be enough to keep it clear, so recently upped it to six hours a day..... just got to wondering if maybe there was too much restriction in the plumbing for this pump to be able to circulate as much as it can. I have another Intex eyeball as well as I have the Hayward eyeball that came with the skimmer that I could add to the system, just wondering what the recommendations are for how much more inlet I need to increase my circulation… And whether the single skimmer is going to be enough. It just has the 1 1/2” Intex hose coming out of the filter, but the Intex eyeball restricts the flow pretty good. I also have the option of using the smaller 1 1/4” ports that are left from the original suction ports for the original pump, that could be turned in to additional inlets without having to cut holes in the pool, but they are flanking the skimmer and probably wouldn’t be the best spot to promote good flow into the skimmer.
Any suggestions are welcome
