So I've been using a TF-100 for a little while now and here are my last two tests. It rained quite a bit last week and again this week and the water went from clear to cloudy. So I tested and noticed my FC was low. So I turned up the % on my SWG and increased the filter run time. I should have only done one of those two at a time, but being a brand new pool and owner I'm unfourtanly learning as I go. Soooo I turned up the SWG and did the normal, cleaned filters, baskets and backwashed if it needed it. I was watching the water to see if it would clear up and it still reamained cloudy. So I ran test again a week later and my FC was at 12.5, PH was 8.2. So I turned my SWG off and from reading on here let the sun and time lower my FC, I also added some Muratic Acid to lower PH and some Calcium Chlorideto bring up Calcium Hardness both additions according to Pool Math. Gave it another week and still cloudy and here are my results from today and last week when my FC and PH were high. My FC is low so I turned my SWG back on and lowered the % this time so I don't run it up to 12.5 again. I'm trying to figure out the correct % and run time of my SWG to stay in the right area and my PH is 7.6, but I'm confused on my the water is so cloudy and won't clear up. I thought it was to low of FC at first, so I ran it up and thinking it would clear up and then read where concentrated amounts can also be cloudy so I turned it off to bring it down. However during the up and down of the FC it never even attempted to clear up. I'm doing something wrong just not sure where. Thanks for any and all the help.
Last week-Cloudy water
FC-12.5
CC-.5
PH-8.2
TA-110
CH-150
CYA-55
Salt-2800
Temp-72
CSI-.18
Today- Cloudy water
FC-2.0
CC-0.0
PH-7.6
TA-90
CH-375
CYA-60
Salt-2900
Temp-69
CSI-.17
FC-12.5
CC-.5
PH-8.2
TA-110
CH-150
CYA-55
Salt-2800
Temp-72
CSI-.18
Today- Cloudy water
FC-2.0
CC-0.0
PH-7.6
TA-90
CH-375
CYA-60
Salt-2900
Temp-69
CSI-.17
