So I own a Dr Wellness spa that I love.
One thing that I learned without a fact, is clarifier is garbage. As soon as you add it to hot tub it turns to gunk, literally a thick gel film. Perhaps a tiny bit is ok, but anything more is awful.
I thought for the longest time that my issue was the clarifier was grabbing stuff from the water and forming that gunk, im pretty sure its the clarifier itself.
Ahhsome is ahhsome - duh.
Hot tubs are 10x more work than pools haha. - Ive had my pool now since memorial day and havent touched it but 1 time. I had to add a couple bags of salt. Thats it. Cant imagine not owning a SWG at this point. However this hot tub, even with an SWG (just works when pumps are on) I feel like half the time or all the time it isnt working. Water level (because its hot) drops way quicker. Chemicals are much harder to balance etc etc etc. Its a pain in the arse quite honestly.
CYA in hot tub - So after my tub went green last winter ive been much better about keeping my CYA levels up, but seriously Should CYA go from 50 to 0 in a month or less? Is that normal? Just seems like a Lot of loss over a quick period.
Dont let your PH Drift. I had been fighting a chlorine problem for a week after I FINALLY got it cleaned (because CYA dropped without me noticing) and I kept fighting and fighting. finally checking the PH (yes i know, do it more often) and it was 8-8.1 As soon as I got that back in check, the chlorine stabilized.
Im sure there are more, ill add but I have kids screaming usptairs
Would love to figure out the CYA issue.. just seems to be sooooo much cya usage in the tub.
