NC close pool or keep pool open over winter
h-man07
9
Raleigh
This will be our 2nd winter with the pool. Last year I kept the pool open, while only winterizing the waterfall. I was planning the same for this year but after talking to a neighbor who used to keep his pool open but now closes his pool to save on electricity, heating & equipment wear & tear, I'm having second thoughts.
Raleigh NC is has moderate weather. If we get snow it melts in a few days time. So the weather allows for the pool to be open year round. Maintenance last year was easy but the equipment is running all the time. If I keep the pool open I was going to use the solar blankets to help with evaporation on the colder nights.
How many owners in similar climates keep their pool open vs closing? Why do you choose one over the other? Thanks,
YippeeSkippy
14,963
Evans, Georgia
hey there.... You can cut down your pump run time greatly in the winter and save a ton on electricity, although I will run mine for 12 hours overnight only when its freezing just to keep the water moving in the pipes. My pool is not closed, but is autocovered. I test it occasionally during the winter and use liquid chlorine as needed, since my SWG is off during winter.
Will snow cause a solar blanket to fall in to the pool, off the surface? I dunno....never used one. I suspect it won't be enough. I think some sort of full coverage tarp would be better- protects the entire pool and keeps animals from falling in.
Maddie :flower:
mas985
13,825
Pleasanton, CA
I keep my pool open all year. The problem with fully closing a pool in a moderate climate is that algae would take over at some point and then you have the mess to clean up in the spring. I much prefer to keep chlorine in the pool and filter at a much shorter schedule (3 hrs/day). I also have the spa so sometimes we heat that up in the winter.
Homebrewale
330
Apex, NC
I'm from the Raleigh area. I close my pool each year. That may change this year because my water is staying warmer than it would have it in the past. One reason is that I don't get the cold rain in my pool anymore due to the change to a solid safety cover. The reason I close my pool is that for 5-6 months, I just don't want to think about my pool. I don't want to have to go out each day in January and inspect my equipment to see if it is functioning properly. It may be dumb luck but I have never opened a pool with algae in the 13 years that I have closed it.
YippeeSkippy
14,963
Evans, Georgia
I forgot to mention that Skippy covers our equipment pad in the winter. He uses old moving blankets covered by a waterproof tarp, and under the blankets he puts an auto light hanging which hopefully keeps things just a few degrees warmer in the pipes.
Maddie :flower:
h-man07
9
Raleigh
Thanks for the replies. I hadn't considered reducing the equipment run times. I will be adjusting the run times this year and keeping the pool open. I used the technique, moving blankets & tent/tarp over the equipment during the winter.
