Naturesoft / Hayward T-15 cell
shovlpushr
3
Goodyear Az
The system was showing 2200 ppm yesterday. Lights for low salt and inspect cell both flashing. No chlorine being generated. Cleaned cell, though not bad buildup at all. Had the water tested and they (local pool store) said salt was at 3200. They tested cell and said it is working but that doesn't tell how well. Added cya (about 5 lbs) and shock (2 bags) at their recommendations.
Today system shows 2500 ppm, lights for low salt and check cell still flashing but says chlorine IS being generated (so far).
Question: Is the low reading of the salt likely from the cell going bad? I think the cell is nearing 5 yrs old.
Any advice? Thanks for sharing your knowledge. :)
jblizzle
43,238
:wave: Welcome to TFP!!!
If the cell is clean, then the low salt reading compared to independent testing is a sign of a failing cell.
Note we do not trust pool store testing, not that you reported any results, but why add 5 pounds of CYA? Why 2 bags of shock and what was the actual ingredient?
TFP's foundation is only adding what your pool needs based on accurate test results from one of the recommended test kits (not pool store testing).
shovlpushr
3
Goodyear Az
was gone for a week on mini vacation. When we returned pool had algae spots throughout. Tested water and levels of cya and chlorine were at 0. Added calcium hypochlorite (HTH brand shock) to quick kill algae. Cya at rate on bag for 12-14k pool. My test kit is basic and only shows chlorine and Ph. Use pool store test (about every other week or so) for anything else Suggestions for a more complete test kit?
shovlpushr
3
Goodyear Az
At the time of return is when all the lights were flashing and no chlorine was being generated.
wireform
In The Industry
Aug 15, 2017
614
Spring Valley, NY
I think you have to recalibrate/reset the hayward control and make sure the correct cell is what the control has. Get yourself the right testing kit TF100 and the salinity kit ,Taylor 1766. Then you'll be sure the cell is toast.
jblizzle
43,238
Agree with the above, TF-100 from tftestkits.net and the Taylor salt kit ... then no need to go to the pool store.
Note that if you had algae, a little cal-hypo is not going to eradicate it. We recommend following the SLAM Process
