Mystery suction-side pipe?! (+ introduction)
RandyO
4
Fort Smith, Arkansas
Hello, TFP forum! :wave: Before I get to my question, a quick intro:
My family purchased a foreclosure home with an in-ground pool 1.5 years ago, and I spent last summer trying to get the pool up and running. We followed advice from this site given to others who had dealt with foreclosure pools that had turned into ponds, and after pulling out solids (rotten leaves, garbage, dog toys, pool toys, & a tangled mesh cover), followed by several weeks of SLAMing and brushing (and, after over a week of watching dead, suspended algae pass through our filter, eventually also used Chlorox Crazy Clarifier with immediate results), we were eventually, finally rewarded with sparkling, inviting water! I would like to extend a HUGE THANK YOU to the operators of this site, as well as the folks who volunteered their time offering advice to strangers on the internet for all of us to benefit from.
We really had no idea what to expect when we first flipped the power switch, but were pleasantly surprised to find that the pump, filter, and plumbing all seemed to work alright, albeit with plenty of leaks, both in the liner and the plumbing. I've resolved most of those by now, having patched the liner in several places, replaced the Jandy valves, the spider gasket in the multiport valve, and lubing lots of other seals, but still have a small amount of air coming in somewhere. Since the pump strainer basket is broken at the drain plug (missing a piece where the o-ring would ordinarily seal), I went ahead and ordered a replacement 2-speed pump, hoping to save energy and fix the air leak, and bank a spare pump.
Now, the point of this post:
On the intake plumbing, I have a 3-way Jandy valve that clearly switches between the single skimmer and the main drain. Tying into the output of that valve is the output of a 2-way Jandy. My experience last year was that opening that valve would cause the pump to immediately lose its prime, unless I opened it very, very slowly. I also noted that the water level in the pool seemed to be going up, which was very confusing as I had been losing water to liner leaks! I wasn't quite sure where the water was coming from. I thought it might have been seeping into the pool through the liner leaks. I've recently confirmed, though, that opening the valve in question does cause the water level in the pool to go up rather quickly. My best guess is that it's tapping into some kind of well point or cistern. My question for this forum is the following: would the purpose have been to serve as a "free" water source, or a way to deal with ground water problems that might otherwise cause liner float?
There are lots of large liner wrinkles, and the liner is bleached out, stained from mud, and brittle from age. I do plan to replace it after this season, but it would be very nice to know before replacing it if I should be keeping that valve open (and the well point/cistern dry) to keep the liner from floating! The pool is located on about the mid-point of a sloped property, which does accumulate standing water at the bottom. I'd estimate the standing water at the bottom of the property to be close to the level of the deep end of the pool. The shallow end of the pool is where most of the liner wrinkles are, though.
If you've made it this far, thanks for taking the time! I tried my best to be succinct, but it can be a struggle, sometimes! :LOL:
Texas Splash
33,451
Fiberglass
CircuPool RJ-45 Plus
Well, I made it! :salut: Ha. Welcome to TFP! :wave: Interesting abut the source of whee that pipe is sucking water from. You wouldn't think you'd want ground water arbitrarily sucked into the pool, but maybe it's a quick resolution to a potentially major issue (pool floating). Maybe @jimmythegreek has seen this before?
jimmythegreek
In The Industry
Aug 10, 2017
3,855
Morris Cnty NJ
Are you sure there is a well point or a leech field under the pool?
I have seen this before and done something similar but not with a pool pump I've done it into a sump pit. If I'm fact you have am underground grid the purpose is to dewater but you set the valve to waste amd pump the water out not into the pool. Hard to tell how clean the water is as it's going thru the filter
Reactions: Texas Splash
RandyO
4
No, I’m not really sure of anything except that I’ve noticed a correlation of water rising in the pool when I open that valve, and that it was hard (last season) to avoid losing the prime when I’d open that valve. This year, it’s been pretty soggy, and it seems to be no issue opening that valve. I might try opening it, and close off the skimmer and main drain, then see what the water in the strainer basket looks like. Or switch to waste, and then capture some of it to test/scrutinize... Although I have my doubts that it will provide sufficient flow to avoid starving the pump.
Would a “leach field” be something like septic laterals?
Just searched it, and see that's pretty much exactly what it is. Any suggestions as to how I might find out, short of digging? ?‍♂️
jimmythegreek
In The Industry
Aug 10, 2017
3,855
Morris Cnty NJ
What you do is let it build up for a few days if wet and then slowly turn the valve so its primed sort of speak amd turn off pump. Then switch to waste amd shoot into a garbage can and use a white tshirt or rag to see water quality. Its just like septic laterals in stone under the pool floor
RandyO
4
After doing some more reading, I'm now thinking that we it's probably a sump tied straight into our main pump, as described at the end of this article, under "Sump’thing to consider".
@jimmythegreek really appreciate the suggestion! I'll certainly give that a try.
I'm now wondering how I'm supposed to control the water build-up in winter, when the pump has been drained? Was just reading how it might be better to keep the pool as full as possible over winter, and not drain below skimmer/jets, in order to fight hydrostatic pressure on the pool floor. Sure would hate to spend the dough on a new liner, and then promptly have floating problems!
RandyO
4
We've only had the pool for one season, and have no ability to communicate with prior owners, so I can't say for certain whether it has floated before. There are plenty of wrinkles in the liner, but I understand that can also have other causes besides a floated liner...
