My results with Taylor k2006c
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Pentair Intellichlor IC-20
I’ve just started adding my CYA via the sock method, says to add 10 pounds, I’ve started low at 4 pounds and will go from there. Salts a little high, and TA is slightly high. Any major concerns from the pros.
17,500 gallon, fibreglass, Salt water.
P.H. 7.4
T.A 90
C.H 420
F.C 2.4
Salt 4000 ppm
Salt 4000 ppm
CYA not registering anything yet
Temp: 84
Thanks for any input,
Ed
mknauss
39,675
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
4 lbs of stabilizer in your pool volume is 26 ppm CYA. So you may not fully read that even when completely dissolved. Was their CYA in this water before?
At what FC generation per day do you have your SWCG set at? While raising your CYA, I would set it at 4 ppm FC per day. You do not show what IC you have so I can not give you % generation/pump run time.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
There was no CYA in the water before it’s a brand new pool. I have the Pentair IC 20, yes I should have got the IC40 but I’ll have to wait until this one dies now....It’s brand new. I have the pump running 24/7 and below is a picture of my IC 20 and what it is running at.
mknauss
39,675
Laughlin, NV
Fiberglass
Great. So starting dissolving another 4 lbs of CYA.
Set the SWCG At 90% for 24 hours per day. Then test your FC each evening and adjust the % generation as necessary to keep you FC at or above about 6ppm.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok I’ll add another 4 pounds today. My pool math app says my recommended FC is 3ppm. I still want to go up to 6ppm??
thanks for the help.
Ed
mknauss
39,675
Laughlin, NV
Fiberglass
Your goal CYA is 70 ppm. So use that for FC. Target for that level with a SWCG is 5ppm.
In your situation, I would be concerned that the SWCG could not keep up with FC loss from the sun. Approximately half of the FC added will be at night, but all of the FC loss is during the day. So you could easily drop below target level in the early evening. So test FC in the early evening.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok will do, I’ll keep you posted. So to turn my IC-20 to 90% I basically just hit the “more” button one more time to get it up between the 80% and 100%?
thanks,
Ed
mknauss
39,675
Laughlin, NV
Fiberglass
So you do not have automation?
mknauss
39,675
Laughlin, NV
Fiberglass
OK -- that limits your settings to 80% or 100%. The Pentair equipment is designed to be used with their automation, not for standalone operation.
So, set it at 80% for now and check your FC in the early evening. If below 5-6 ppm at that time, raise to 100%. I suspect you are going to have to use the pump run time, or at least pump rpm, to zero in on your FC needs with your system.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok sounds good. What automation do you recommend I buy
mknauss
39,675
Laughlin, NV
Fiberglass
Pentair has several different levels of Automation. The basic system is IntelliConnect. The one wild card is your pump. The Supermax (also called Superflo) was not controllable via automation in the past. But if your pump was manufactured after November 2020, then it is automation controllable.
The Intelliconnect has draw backs as it uses a Pentair app to remotely control your equipment. It has shown to have issues.
I would suggest you work with your pool this summer to see how it goes. If you are satisfied with what you have, great. If it becomes an issue, then investigating automation may be a good plan .
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Sounds good. I’m 2-3 weeks deep into a brand new pool, never owned one before. It’s all very new. I will say the water is crystal clear so far....knock on wood.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok, I have started to register some CYA, 8 pounds added and I am going to wait a couple days and test again. Tonight’s results were as follows. I did up my SWCG to 80% and my pump is running at 2400 RPM.
PH 7.2
TA 80
CH 420
Salt 4000
FC 2.4
CC 0.4
CYA 40
thanks,
Ed
mknauss
39,675
Laughlin, NV
Fiberglass
Tomorrow you should add a gallon of 10% liquid chlorine to add 5 ppm FC. The SWCG is to maintain the FC. You need to get the FC up to or above target range with LC.
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok I will do that tomorrow, can I just dump the jug right into the pool or does it need to be pre mixed with water and can the kids swim right away or keep them out for a bit.
thanks again, really appreciated.
Ed
mknauss
39,675
Laughlin, NV
Fiberglass
Pour it slowly at a return with the pump running. Let the kids in 15 minutes after.
Reactions: Edward13911
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Ok so I did my early evening test after adding 8lbs Of CYA, adding a gallon of liquid chlorine and increasing my SWCG to 80%. And this is the current result.
FC 10
CC 0.2
PH 7.6
TA 100
CYA 50
thanks,
Ed
Edward13911
Active member
Feb 15, 2021
44
Ontario, Canada
Fiberglass
Early morning test result.
FC 10.6
CC 0.2
PH 7.6
TA 120
CYA 50
I will lower my PH a bit and aerate to bring down TA. My FC went up .6 over night so I suppose it’s good I’m not losing any but seems high, any suggestions or concerns @mknauss
CrystalRiver
642
Massachusetts
Overnight, there's no sun to consume FC. If you didn't have a SWG running, and tested after sunset and again before sunrise, your should have essentially zero FC loss. I'm concerned that yours only went up 0.6.
Speaking of 0.6, that tells me you're using a 25 mL sample size. Using a 10 mL sample is fine, and uses significantly less reagents. Pools don't need the 0.2 level of precision that 25 mL sampling provides.
Anywhere between target and SLAM level on the FC/CYA chart is safe for both your pool and your kids to swim in. Especially while getting your SWG dialed in, it's best not to be too close to the bottom of target, nor SLAM level, since we aren't sure what your pool is going to do yet.
Keep testing and reporting your results. We'll get it dialed in and you'll know what to expect in short order.
Reactions: mknauss
